JD 850 Question
/ JD 850 Question #1
bodywash
My JD 1984 850 has approximately 900 hrs on it. It starts easy, runs great, seems to have lots of power etc. However, it has a fairly loud knock which is most noticeable at idle. It also smokes a bit -- appears to be white smoke with MAYBE a touch of blue. Every few seconds it appears to puff out more smoke than usual, and I think it also makes a very light bump sound when it puffs the smoke. There is no water in the oil, no gas bubbles in the radiator. It has new injectors. Any ideas on what I should look for? Thanks
Scott
/ JD 850 Question #2
Make sure your delivery valves are tight. those are the "fittings" that stick out of the injection pump.
/ JD 850 Question #3
Your JD 850 has a Yanmar engine which is known for making a fairly loud knock especially when cold, "Yanmar Hammer". I believe that the condition you are describing is normal for this engine. I would try a little Power Service in the fuel to see if it helps the smoking problem.
Ken /forums/images/graemlins/smile.gif
/ JD 850 Question #4
If it is only at slow idle, I am not sure I would worry too much. I have an '84 JD 950 with 2100+ hours. It is also pretty loud at slow idle but smooths out as I increase the rpms. Mine doesn't smoke though except when I first start it up or put it under heavy load.
208320 (A58375)
208320 (A58375)
John Deere S350 (A60462)
John Deere S350...
2010 Honda Accord Passenger Car, VIN # 5KBCP3F82AB012291 (A61165)
2010 Honda Accord...
2023 John Deere 9RX 540 Track Tractor (A63109)
2023 John Deere...
2016 HAMM H11IXP PADFOOT ROLLER (A62129)
2016 HAMM H11IXP...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
