JD 850 needs a clutch
   / JD 850 needs a clutch #11
The job I did on mine was a couple of years ago but I used both the inner and outer drive lines as the alignment tools, worked perfectly. Removed these to change the throw out bearing and springs anyway. Setting the fingers on the pressure plates was done with a square and, again, turned out perfectly, no special tools needed. Yes, I did get my clutches and pressure plates rebuilt localy and it seams I paid less than $130 for all. Time has a way of changing prices though. Even if you buy a alignment tool and a setting ring you will still be way under the cost of having someone else do the job and you will have the tools for the next clutch change. Think that will be many years in the future though. If your tools are limited or you don't have a place to work, might want to think about paying for the work. Good luck,
Chris
   / JD 850 needs a clutch #12
I helped my neighbor with a large 85hp tractor. He bought a "universal" alignment tool from one of the local auto parts or Napa stores for lining up the clutch. It had a bunch of bushings and a spring loaded conical section. It was cheaper that the prices you are looking at.
We blocked the motor the front wheels and the front half of the tractor right ahead of the split and used a special cart to roll the back half away.
The cart is not that hard to fab if you have some metal skills. The base is T shaped with 3 wheels on it (one at each end point). The "bottom" of the T is lined up under the back pumpkin and is blocked there. At both ends of the top of the tee is a height adjustable riser which get bolted to the tractor casting where an attachement point permits. Put a bit of upward tension on these, unbolt the halves and roll back.
I've done a smaller tractor the harder way and this cart was well worth making.
The suggestion on the Cart is a great idea. I have some heavy duty angel iron available and will see about welding up something. I broke down and ordered a rebuilt clutch from a supplier. Haven't seen delivery on it yet. I still need to order up bearings and springs to complete the parts needed. I am not sure when I will start this project due to the distant location, however when I do I will attempt to document it with pictures and verbage.
regards, Phil C.
   / JD 850 needs a clutch #14
Hi Phil,
It looks like your pto clutch disk is rusted on to it's drive and driven plates from none use over a long period of time. This is not unusual on tractors, especially the Yanmar built JD's. A lot of clutch disk's have metallic wire woven lining's that simply rust up to their drive plates with a little bit of moisture.
Before splitting tractor try to break disk free by doing what you did earlier
(running down t/o bearing adjustment all the way). Then put on a pto drive shaft (bush hog, etc.) and finding a way to lock the shaft up (long pipe wrench etc.). The next step is to bump the starter and hope that this will break disk loose. And even better way is set tractor, with bush hog over a large grass clump and then lower hog unto the the clump while holding clutch pedal all the way down. Hopefully this high shear load on disk may break it free.
Also, when lining up tractor bell housing to engine it is helpful to get at least 4 extra long coupling bolts, cut their heads off and use them as dowels for lining up the two faces. Chamfer ends and put two blades on hacksaw and cut a screwdriver slot on dowels for removal. This will make the job much easier. Be sure to keep the two flanges equally parallel all the way around housing while bringing it together.
On height adjusting tool, be sure to measure finger height on old clutch before disassembling and set new one the same or close (new disk will have less) and you should be ok.
On the spline alignment tool, universal clutch alignment tools are made by Snap On and others which use variable tapered nose's. These are not as good an OEM pilot tool or shaft but will do most of the time.
Phil, lots of luck
First I tried lowering the Brushhog on to a few maple trees while holding the clutch all the way in. This attempt did not break the clutch loose.
I was able to disengage the PTO clutch by over adjusting the clutch pedal linkage. Unfortunetly, with the linkage over adjusted the driven clutch was disengaged all the time. I did this to make sure that the PTO clutch disk was not frozen to the fly wheel. When I bought the tractor (used) I was told that it was mainly used as a loader. I suspect that the driven clutch disk is well warn from this use and has been adjusted out to its limit. Your suggestion on the extra long bolts used as dowels is a good idea. I'll have to remove one of the bellhousing bolts as a sample and go visit my local metric bolt supplier.
   / JD 850 needs a clutch #16
I have found a rebuilt clutch for little less than half of a new one. (now things are getting a llittle more reasonable). But I still need to locate the special tools needed, the Clutch disk alignment tool and Finger height alignment tool. I could probably just turn down a piece of shaft on the lathe for the disk alignment tool and mimic the transmission input shafting, however I am unsure of the Finger alignment tool. This too could be made pretty easily, if I had the proper demensions. JD parts on line list these puppies out at $63.53 and $72.17 (not in stock either!). Not trying to Cheap out here, it's just that this project was not in this year's budget, So I need to keep it as low as possible before presenting this to the family Finance officer, if you catch my drift.
regards,Phil C.
This post is a little old, curious how it worked out since I have a JD 850 2 Wheel Drive with a 2 stage clutch. Anything to share?
   / JD 850 needs a clutch #17
My 750 has a dragging clutch problem and I have been looking at options. For anyone facing this I suggest going to the Hoye tractor site, there is a clutch replacement video that walks you through the process. Our JD’s being green Yanmar should make this info pertinent to ours as well. Ebay shows clutch, pressure plate, through out bearing, pilot bearing and alignment tool for under 200 bucks.
I traded with a local guy to replace the clutch. So far it has been fine. The old clutch wasn稚 really warm out badly, but the tractor had been used a lot as a loader so the drive disc wore much quicker than the PTO portion
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2023 QUALITY CARGO 16 T/A ENCLOSED TRAILER (A50854)
2023 QUALITY CARGO...
