JD 850 Crank case Oil fill level
   / JD 850 Crank case Oil fill level #1
bodywash
My '84 JD 850 owners manual states a crackcase oil change with filter should be 4.7 quarts. When I fill my 850 with this much oil it only registers about 1/3 the way up on the cross hatch marks on the oil dip stick. So:
Is 4.7 quarts the correct oil amount, or should I fill it upto the top of the dipstick cross hatch.
Thanks
Scott
   / JD 850 Crank case Oil fill level #2
bodywash,
Run it for a few minutes at its current level then shut it down, wait a couple minutes and re-measure. (Now the filter is full...). At this point, fill to correct level using the dipstick.
Over the years, I have found many typos in manuals as they relate to capacity. Sometimes they're off by quite a bit.
Brian
   / JD 850 Crank case Oil fill level #3
I believe my JD 850 owners manual says the same thing.
I add just under 6 quarts to get to the full line.
   / JD 850 Crank case Oil fill level #4
I have an '84 950. Not sure I ever looked at the manual to see how much oil it says is needed. I buy by the gallon and pour in enough to get to the normal level. Then run it for a few minutes to allow the filter to fill up. Stop it and wait a few minutes. Then add more oil to bring it to the full mark.
378809 (A51573)
378809 (A51573)
2001 Dodge Ram Wagon Passenger Van (A51692)
2001 Dodge Ram...
2017 Dodge Caravan Van (A50324)
2017 Dodge Caravan...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2012 Ford Expedition XLT 4x4 SUV (A50324)
2012 Ford...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
