JD 850 Crank case Oil fill level
   / JD 850 Crank case Oil fill level #1
bodywash
My '84 JD 850 owners manual states a crackcase oil change with filter should be 4.7 quarts. When I fill my 850 with this much oil it only registers about 1/3 the way up on the cross hatch marks on the oil dip stick. So:
Is 4.7 quarts the correct oil amount, or should I fill it upto the top of the dipstick cross hatch.
Thanks
Scott
   / JD 850 Crank case Oil fill level #2
bodywash,
Run it for a few minutes at its current level then shut it down, wait a couple minutes and re-measure. (Now the filter is full...). At this point, fill to correct level using the dipstick.
Over the years, I have found many typos in manuals as they relate to capacity. Sometimes they're off by quite a bit.
Brian
   / JD 850 Crank case Oil fill level #3
I believe my JD 850 owners manual says the same thing.
I add just under 6 quarts to get to the full line.
   / JD 850 Crank case Oil fill level #4
I have an '84 950. Not sure I ever looked at the manual to see how much oil it says is needed. I buy by the gallon and pour in enough to get to the normal level. Then run it for a few minutes to allow the filter to fill up. Stop it and wait a few minutes. Then add more oil to bring it to the full mark.
16ft T/A Flatbed Equipment Trailer (A50323)
16ft T/A Flatbed...
2015 Toyota Prius Hatchback Sedan (A50324)
2015 Toyota Prius...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
