JD 850 Crank case Oil fill level
   / JD 850 Crank case Oil fill level #1
bodywash
My '84 JD 850 owners manual states a crackcase oil change with filter should be 4.7 quarts. When I fill my 850 with this much oil it only registers about 1/3 the way up on the cross hatch marks on the oil dip stick. So:
Is 4.7 quarts the correct oil amount, or should I fill it upto the top of the dipstick cross hatch.
Scott
   / JD 850 Crank case Oil fill level #2
bodywash,
Run it for a few minutes at its current level then shut it down, wait a couple minutes and re-measure. (Now the filter is full...). At this point, fill to correct level using the dipstick.
Over the years, I have found many typos in manuals as they relate to capacity. Sometimes they're off by quite a bit.
Brian
   / JD 850 Crank case Oil fill level #3
I believe my JD 850 owners manual says the same thing.
I add just under 6 quarts to get to the full line.
   / JD 850 Crank case Oil fill level #4
I have an '84 950. Not sure I ever looked at the manual to see how much oil it says is needed. I buy by the gallon and pour in enough to get to the normal level. Then run it for a few minutes to allow the filter to fill up. Stop it and wait a few minutes. Then add more oil to bring it to the full mark.
1997 TRAILMOBILE 48X96 FLATBED TRAILER (A50854)
1997 TRAILMOBILE...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
2013 Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
2013 Case 84in...
2008 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2008 MAGNUM...
Landoll (A50657)
Landoll (A50657)
