JD 790 ?
/ JD 790 ? #1
countrybumpkin
Elite Member
Kioti, kubota
I'm looking at a 790 4WD fel 280 hours, they are asking 9500 for it. Does this sound like a fair price? And will it work a 5 foot bush hog , in mild feild work. I've got a 2310 2wd long but not sure of the Hp of it. It does about right with the bushhog , but would like the 4WD and FEL.
/ JD 790 ? #2
I'm running a 5' cutter behind my 790. It does a fine job using 2nd or 3rd Low range (about as fast as I'd want to go on the field I mow).
At the worst, if the brush is really thick, I may have to drop a gear or make a partial pass. Since those cutter blades spin so quick (and take so long to slow), shifting isn't any problem.
I keep the loader on as counter balance but might try it without the FEL next time I cut. I don't think I'd raise the 3PH without the loader or front weights however.
Bottom line...that 790 will do a fine job on that brush.
The price sounds really good. I suspect that tractor is one of the older 790's with the #70 loader. I'd buy it in a hearbeat!
/ JD 790 ? #3
Does it have a vertical stack or is it hidden under the hood? If it is vertical, then I am betting it is the 30HP model. Regardless, it is a good price for such a low use tractor.
/ JD 790 ? #4
That does sound like a good price and you'll love the 4wd and FEL. Like Roy, I run a five foot cutter with no problem. FEL or front weights, it gets light in the front with neither. Unlike Roy though, I'll mow in 2 Hi mostly. I'm generally mowing well kept weeds, nothing more than a foot high normally and it's not too thick /forums/images/graemlins/smile.gif
/ JD 790 ? #5
The 790 will handle a 5' brush hog with no problem.
I have a 6' and only need to remember to have the RPMs down when I engage the clutch. I also keep the FEL on, but mostly to knock over and dig up the multiflora roses that are trying to take over the field.
2019 Ram 3500 4x4 Reading Service Truck (A61573)
2019 Ram 3500 4x4...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
