JD 790 Spool Valve Install
/ JD 790 Spool Valve Install #1
Wsmitty
Peterstown, WV
New Hollan 1720
I'm planning to add a TNT to my 790. I was able to get my hands on a BM18005 Power Beyond kit, so this is what I'm working with. Also If I can ever find a #7 backhoe I'll be set for that.
As far as the spool valve, I'll be using one with the Power Beyond feature. The spool valve will be fed from the tractor PB "To Valve" coupler, the PB port on the valve will go to the "From Remote Valve" coupler and the spool valve output port will be returned to the case / tank.
Does anyone have a clue as to where I can tie in the tank return from the valve output to this tractor? I'm not seeing a spot to tie into. Here is a pic of what I'm trying to do.
/ JD 790 Spool Valve Install #2
Go to the top of the page and click on ALERTS. then on inbox. You have a PM.
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
GUIDED FISHING TRIP FOR TWO - HISTORIC SOQUE RIVER (A64277)
GUIDED FISHING...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
2003 International 4300 Bucket Truck (A62613)
2003 International...
