JD 790 Spool Valve Install
/ JD 790 Spool Valve Install #1
Wsmitty
Peterstown, WV
New Hollan 1720
I'm planning to add a TNT to my 790. I was able to get my hands on a BM18005 Power Beyond kit, so this is what I'm working with. Also If I can ever find a #7 backhoe I'll be set for that.
As far as the spool valve, I'll be using one with the Power Beyond feature. The spool valve will be fed from the tractor PB "To Valve" coupler, the PB port on the valve will go to the "From Remote Valve" coupler and the spool valve output port will be returned to the case / tank.
Does anyone have a clue as to where I can tie in the tank return from the valve output to this tractor? I'm not seeing a spot to tie into. Here is a pic of what I'm trying to do.
/ JD 790 Spool Valve Install #2
Go to the top of the page and click on ALERTS. then on inbox. You have a PM.
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
Skid Steer Boxbroom Sweeper (A64047)
Skid Steer...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
iDrive TDS-2010H...
1984 John Deere 750 Utility Tractor (A63116)
1984 John Deere...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
