Grapple JD 790 Grapple?
   / JD 790 Grapple? #11
Millonzi has a deere adapter for $50. I know it fits my 200cx and has a set of pins a few inches lower so it should fit a 300 loader also. JC
   / JD 790 Grapple? #12
I don't have a QA on my loader. I simply supplied some measurements from my loader, Millonzi verified them with a local Mahindra dealer, and they welded pin-on brackets on my grapple. It was a 5 minute job to drop my bucket and pin the grapple on. The bucket hasn't been back on since. :D I think I paid an extra $100 for the pin-on brackets.
Good luck,
BR
   / JD 790 Grapple? #13
BamaRob said:
Check out my Grapple Install thread. The Millonzi International LD-48 Grapple weighs in at just 285 lbs. I've got about $1500 total in the grapple, WR Long Electric Hydraulic Valve, bulkhead kit, hoses, etc.
I think the Millonzi LD-48 is the best bet for the limited lift capacities of our compacts. I'm having a blast with mine. It does a great job cleaning up brush.
Good luck,
BR
I had the same concerns about lift capacity for my GC2310 and spoke with the folks at Millonzi - They feel they can change a cross bar and reduce the weight by yet another 45 pounds to 240 pounds without comprimising the product and in consideration of the capacities of the tractor.
I am following Islands setup with running from rear remotes I am planning on installing. That way I can add a hydraulic top link for my BB as well.
Dan
   / JD 790 Grapple? #14
You can also go with the pins set up rather than QA which will save about 100lbs.
   / JD 790 Grapple? #15
I just got my new grapple for my 990 here is the JD mount for it.
The electric valve from WR Long
My new forks
   / JD 790 Grapple? #16
Very nice. Do you have full dump and curl function with that JD specific mount? Is that the JD QA mount (I've never seen one up close)?
   / JD 790 Grapple? #17
yes , I have full dump and curl function
   / JD 790 Grapple? #18
Then that is a very nice solution. I have the QA adapter but honestly if I were to do it again I would think long and hard about the pin version. I see that you also got forks with the pin attachment. I suppose that after accummulating about 4 or 5 implements the QA system would pay for itself but for someone who intends to go only from bucket to grapple to forks and not on a daily basis, the pin on makes a lot of sense both economically and to save weight and load capacity.
   / JD 790 Grapple?
Willl who makes that grapple? I have never seen one quite like it. Keep the pics coming.:)
30006 (A53424)
30006 (A53424)
Bomag BW213D Vibratory Soil Compactor (A55851)
Bomag BW213D...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
2018 KENWORTH T880 DAYCAB (A55745)
2018 KENWORTH T880...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
2014 TRAIL KING JBTR-38 (A55745)
2014 TRAIL KING...
