jd 7775 skid steer
/ jd 7775 skid steer #1
rlj
Just bought a 1998 7775 and it has a line behind all wheels that goes to the axles three of them are ripped .The one that is still attached has grease fitting on it.Is this to grease axle splin or wheel bearing? It looks like to me the bearingruns in the hydro oil.
/ jd 7775 skid steer #2
I belive the outer bearing is gerase only not oil from the chain case. never seen one with hoses to grease the axles. most times you have to pull the wheels to grease unless they are set wide . they dont need to be gerased that often.:)
