JD 755 not starting.
/ JD 755 not starting. #1
65specialk
Kubota L 7800
755 fuel relay????. Can any one help???
Dave
/ JD 755 not starting. #2
To help, will need more information. Tell us more.
/ JD 755 not starting. #3
First off the thing is obviously cranking right is there smoke coming out the exhaust? If not make sure there is fuel in the fuel filter sight glass if not it broke prime ran out of fuel? If there is fuel and no smoking more than likely its the fuel soliniod on the fuel pump it has three wires going to it ground power and a pull in wire they go bad and can't get enlightenment amperage to pull it in any other questions email I can walk you through it hope it helps
Can you tell me it's function??? Would it be able to cause a no fuel beyond the dist pump situation?? Dave
/ JD 755 not starting. #7
Have you checked that the fuel solenoid shutoff is working i.e. on when turning the key on?
/ JD 755 not starting. #9
Double check all the pedal and seat interlocks are working correctly, I had a similar problem an the pedals were moved slightly by a tie down chain on the loader arm.
/ JD 755 not starting. #11
