JD 755 Losing power under load
/ JD 755 Losing power under load #1
thomgriz
my jd 755 works great. but sometimes under load, ie snow plowing, plowing, it acts like its fuel starving and takes a minute to recover. a fuel problem?
/ JD 755 Losing power under load #2
When you say it takes a minute to recover, do you mean the tractor regains it's full power?
The 755's are great machines, but are fairly low powered (as was my old 670).
Is it possible you're just running it hard and bogging it down?
/ JD 755 Losing power under load #3
it could also be a worn injection pump. start with the obvious, filters
etc, and go from there.
/ JD 755 Losing power under load #4
I had the same issue with my 755 JD, The fuel tank was loaded with that greenish/black algae which caused ( I believe ) the electric lift pump to fail. It cost me like $ 40 bucks. There is also a screen in the tank that was plugged , this happened at 600 hrs. I bought the machine second hand, who knows what kind of fuel they put in it???? Hope this helps
/ JD 755 Losing power under load #5
When that electric pump starts to go, it will loose power under load and eventually not run above an idle, First filters, then try cleaning out the tank and screen. The hood heeds to come of to get the tank off for proper cleaning . :D
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2014 CHEVROLET CAPRICE (A66091)
2014 CHEVROLET...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
8ft Fork Extensions (A66734)
8ft Fork...
2020 FORD F-150 XL CREW CAB TRUCK (A65054)
2020 FORD F-150 XL...
