JD 755 left rear wheel locks up in forward
   / JD 755 left rear wheel locks up in forward #1
Daveqh
John Deere 755
I have a John Deere 755 that the left rear wheel locks up when going forward. In reverse it turns fine, but I can't seem to get much work done in reverse.http://www.tractorbynet.com/forums/images/smilies/smile.gif
If anyone can give me some ideas on what to look for. I'm ready to take it apart if needed.
Thanks............Dave
   / JD 755 left rear wheel locks up in forward #2
That would be my next step.
Don't force it forward, likely bust something worse if you do.
   / JD 755 left rear wheel locks up in forward #3
Sounds like a broken brake shoe.
E/S
Thanks, I was starting to think the same thing about the brake plates being broken. I forgot to mention the tractor has a Hydrostatic transmission, if that has anything to do with it (?)
   / JD 755 left rear wheel locks up in forward #5
I didn't think 755s had front brakes ?
   / JD 755 left rear wheel locks up in forward #6
   / JD 755 left rear wheel locks up in forward #7
Mine is doing the same thing now, what did you find out?
cmsofmich: Mine is doing the same thing now, what did you find out?
Hi cmsofmich,
I have not yet taken it apart, I did however change the Hydro oil and changed the filter and cleaned the screen. The screen had metal flakes on it, so something is really wrong inside (I think). Afterwords the tractor acted the same so I will be taking it apart as soon as I get a little time.
   / JD 755 left rear wheel locks up in forward #9
Did you ever get to tear it down ? I have a ford 445D same thing exactly, right side only. Looking for a little more info before i tear down this one. Thanks for any and all help! TaterK
   / JD 755 left rear wheel locks up in forward #10
Bad bearing.
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2012 WILCO MACHINE & FAB INC. WILCO MACHINE & FAB INC. (A50854)
2012 WILCO MACHINE...
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
