JD 755 Compact
/ JD 755 Compact #1
Tricky_Rick
I just bought a John Deere 755 and need to know what oil to use for the engine and rear end. Also any tips on general maintainance. I am new to deisel engines and could use some advise...
rick@thisdamnpage.com
/ JD 755 Compact #2
As far as oil, any good quality rated for use in diesel engines will be fine. I normally use 10W-30, but I don't have any preference for a given brand. I guess Quaker State would be my most frequently used brand.
As far as maintenance...try your local Deere dealer (since the place you bought the 755 from didn't have the manual?) to see if they can order you a manual. I know you can buy one at your local Tractor Supply, but it'll be somewhat generic (not a Deere manual).
However, start looking around your tractor for grease (zerk) fittings. You should have one at the front wheels pivot points, the front axle pivot (for steering). The axle U-joints...brake pedal pivots... Reckon you should see 6 or 8 zerk fittings, not including the front end loader (if you've got one). If you've a loader, any place that can pivot or move will have a zerk fitting to lubricate. Per the manual, my 670 should be greased every 10 hours. I use a general purpose high pressure grease.
That 755 is a solid machine. I'm sure you'll enjoy working with it.
/ JD 755 Compact #3
Rick - For manuals you can either call JD at 1-800-522-7448, or register on-line (johndeere.com or deere.com), select Parts and follow registration instructions. Once registered you can order parts and manuals (look for technical publications on lower left of screen) and have them shipped via your local dealer. The parts section has some excellent graphical look up features (look for - "Click here to open John Deere Parts Catalog).
/ JD 755 Compact #4
Glad you finally found this site Rick. Don't worry about the grease as we have plenty of it. We have about 50 tubes of NH grease down in our cellar so help yourself when you need some (plus as everyone knows, using NH brand grease in your JD tractor will raise its resale value /forums/images/graemlins/grin.gif)
/ JD 755 Compact #5
Rick,
I also have a JD 755 (1987). The engine oil depends on the air temperature you experience. I use 10W40 in the Spring/Summer/Fall and 10W30 in the winter. Oil capacity is 2.86 qts. with filter.
I am not sure what you mean by rear end oil. Do you mean the hydraulic oil? If so, the manual calls for JD Low Viscosity Hy-Gard. The machine holds 3.7 gal of hydraulic oil. There is both a replaceable, spin on filter and a reuseable screen.
You did not mention if you have 4WD. If you do, the front axle contains 2.25 qts of API GL-5 Gear Oil. As with engine oil, the weight for the gear oil depends on air temperature. 80W90 is good for -15F to almost 100F.
There are 14 grease fittings on the 755 with 4WD. 16 fittings on the 2WD version.
Don't forget the air filter and fuel filter.
If you have any questions on the 755 let me know. I've been operating mine for the past 15 years and have all the manuals.
Jeff
/ JD 755 Compact #6
A most courteous and helpful reply. This is what TBN is all about. Thank you for the information.
/ JD 755 Compact #7
Sometimes you can great deals on manuals and parts on eBay...
/ JD 755 Compact #8
is this thing a gas model? if not where do you all find 10w30 10w40 diesel rated oil?
/ JD 755 Compact
Thanks a lot for the info..... VERY MUCH APPRECIATED!
Isn't it funny when I can get more info from strangers than a dealer?
/ JD 755 Compact #10
Nobody is stranger than the people out here!!! /forums/images/graemlins/tongue.gif
Take Mike's advice and go to ebay and get your manuals. I see them out there EVERY day. Do a search by John Deere 755 and you'll find not only owner operator manuals but also you might find some maintenance manuals. I have an 855 and am always looking on ebay for a screaming deal.
You'll find that 755 will do most everything you ask. Have fun.
/ JD 755 Compact #11
Shady,
It's a diesel. You bring up a good point about the right oil. I have been using Castrol GT or GTX in my 755 since new. I recall in the beginning the oil was dual rated for both gasolene and diesel engines. It no longer is. To be honest, I have not looked that close at the label nor have I looked for diesel rated oils. I'm not sure how available they are.
I end up changing my oil every 50 to 80 hours in the spring/summer/fall cycle and 15 to 30 hours in the winter cycle. I think frequent oil changes help minimize the impact of using a non-diesel rated oil. I hope /forums/images/graemlins/confused.gif
I am interested in what others are using.
Jeff
/ JD 755 Compact #12
the big problem when using gasoline rated only oils is they use different additives mainly this tends to wear the ring areas more on diesels where the rings are hotter.. according to rotella's tech's on there forum.. kinda caught my eye as i'm looking into finding a good 10w30 for my hino..
2026 WINSTON 20 Ton Tandem Tag-A-Long Trailer (A62613)
2026 WINSTON 20...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
Lot 602 (A62613)
Lot 602 (A62613)
40000SFL (A64556)
40000SFL (A64556)
2003 International 4300 Bucket Truck (A62613)
2003 International...
