JD 750
   / JD 750
Thanks for the offer but I just purchased a manual. Found the problem, the six bolts that hold the carrier to the ring gear were all sheared. new bolts should be here early next week.
   / JD 750 #12
Very nice Joe! I looked high and low for a PDF of the service manual for my 970 and, having not found it, ordered a hard copy and will cut it apart and digitize it into a searchable PDF. Nice to see you helping out like this.
Joe
Shoot me your email and I'll send you a PDF of the Deere tech manual
Sounds like time to do some reading
Joe
   / JD 750 #13
Joe
Hi joecdeere
is the offer for the tech manual open to all?
i could really use it if its for the older 750s mine is a 1984
   / JD 750 #15
gladly, just need your email
   / JD 750 #16
sent you a private message joecdeere
   / JD 750 #17
Then you probably broke one of the pinion shafts. One on each side. The little shaft that goes from the brake drum to the diff.
Wengers of Meyerstown has used ones. CH15033(LH) $175 CH15034(RH) $150 They call it Bull Pinion shaft.
Exactly what I was saying. I broke my right one the first season, it must have been flawed. The dealer was small and very challenged, I had him send the part and gasket and maybe some other parts and I repaired it. That was winter of 1983, so memory not really crisp.
prs
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
LIGHT TOWER (A56857)
SKID STEER BUCKET (A58216)
SKID STEER BUCKET...
SMALL WIRE SCREENS FOR CASE IH COMBINE (A52708)
SMALL WIRE SCREENS...
