JD 750 Remote Spools
/ JD 750 Remote Spools #1
wallace11bravo
Palmyra NE
John Deere 750
Anyone ever worked on the remote cylinder valve on a JD 750?
Bucket tilt has started drifting, a lot and rather suddenly. Reversed the lines just to test and drift goes away (not the cylinder). No (significant) drift on the main rams (not the relief valve). So pretty sure it is the valve, and just the one valve.
Any other ideas or corrections to assumptions above? Anything I should try before tearing into the valve? Is there even any point to tearing into the valve myself, or should I just replace?
/ JD 750 Remote Spools #2
Welcome to TBN
If spool valve is leaking internally only resolution is replacement of complete valve(spool & housing) as the clearance between spool & housing is a machined fit.
72in. Land Plane (A65640)
72in. Land Plane...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
40' Cube Multi-Door Shipping Container (A64127)
40' Cube...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
