JD 750 Remote Spools
/ JD 750 Remote Spools #1
wallace11bravo
Palmyra NE
John Deere 750
Anyone ever worked on the remote cylinder valve on a JD 750?
Bucket tilt has started drifting, a lot and rather suddenly. Reversed the lines just to test and drift goes away (not the cylinder). No (significant) drift on the main rams (not the relief valve). So pretty sure it is the valve, and just the one valve.
Any other ideas or corrections to assumptions above? Anything I should try before tearing into the valve? Is there even any point to tearing into the valve myself, or should I just replace?
/ JD 750 Remote Spools #2
Welcome to TBN
If spool valve is leaking internally only resolution is replacement of complete valve(spool & housing) as the clearance between spool & housing is a machined fit.
2016 Forest River Eliminator Toy Hauler Trailer, VIN # 5NHUELP37GY071306 (A65563)
2016 Forest River...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
Enlon Electric Drive Wood Laythe  (A62679)
Enlon Electric...
