JD 750 Remote Spools
/ JD 750 Remote Spools #1
wallace11bravo
Palmyra NE
John Deere 750
Anyone ever worked on the remote cylinder valve on a JD 750?
Bucket tilt has started drifting, a lot and rather suddenly. Reversed the lines just to test and drift goes away (not the cylinder). No (significant) drift on the main rams (not the relief valve). So pretty sure it is the valve, and just the one valve.
Any other ideas or corrections to assumptions above? Anything I should try before tearing into the valve? Is there even any point to tearing into the valve myself, or should I just replace?
/ JD 750 Remote Spools #2
Welcome to TBN
If spool valve is leaking internally only resolution is replacement of complete valve(spool & housing) as the clearance between spool & housing is a machined fit.
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
1988 LUFKIN END DUMP (A63569)
1988 LUFKIN END...
17109SFL (A61569)
17109SFL (A61569)
Bush Hog 244-7QT Front End Loader (A64047)
Bush Hog 244-7QT...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
John Deere MX6 Bush Hog (A64047)
John Deere MX6...
