Planters JD 71 planter
/ JD 71 planter #1
drz400
Upstate New York
'05 JD 3320
I just picked up a JD 71 single row planter.It has the corn hopper and a few corn plates.Other than corn , will this set-up also plant bush green beans with maybe a different plate?
/ JD 71 planter #2
One of your corn plates should work great for your beans. Just put some seeds in and lift your three point up and try it out.
/ JD 71 planter
I just put my seed order in.I'm waiting for it to arrive. If I measure the seeds(beans) length-width-and depth, can I fit that to a plate with that size cell opening ??? You say the corn plates will also work for beans?
/ JD 71 planter #4
Least complicated way I've found is to simply take a seed and fit it into the plate cell. If it fits, it'll usually work. Oblong seeds like green beans, I have better luck when the cell is SLIGHTLY larger than the seed. Corn likes a fairly close fit. You can measure the seed also. Lincoln AG will list cell size for their plates on the website. I've taken a Dremel tool to a couple corn plates to get a better fit with beans, however, the correct fit, requiring no modification can be found with the right sized plate.
/ JD 71 planter
It sounds like its easy enough to do. Since I work in a machine shop I can fit the seed to a plate. Can't wait till the snow melts so I can try this planter out! Thanks !
2012 CATERPILLAR 316EL EXCAVATOR (A62129)
2012 CATERPILLAR...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2012 International (A59230)
2012 International...
UNUSED WOLVERINE QC7-26-12.5G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
