JD 675B skid steer hyd. charge issue
   / JD 675B skid steer hyd. charge issue #1
jchilcot
Morrisdale PA
1994 John Deere 675B
Hi new member here. I have a skid steer that I recently purchased for some landscaping/brush removal from my property. When I run it the Hyd. charge light comes on. I cleaned the suction screen. It was pretty dirty. I thought for sure that would fix the problem but it hasnt. I have noticed that it will work fine until I lift the boom a couple times. Then it comes on and stays on. Everything seems to still work ok but the engine loses power if I start to work it hard. I have read a trouble shooting guide for the machine and what I got from that is it could be the pressure relief valve. Any thoughts on that? The hydraulic resovoir is full. I dont think its the sender due to the way it is running.
Its a JD 675B by the way.
   / JD 675B skid steer hyd. charge issue #2
Did you also change both hyd filters when you cleaned sump screen?
MG9800098 FILTER ADD 16.29 USD
PMHF28810 HYD. FILTER ADD 20.81 USD
I bought some new filters today. Ill put them on tomorrow.
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
John Deere 3PT PTO Post Hole Digger (A55218)
John Deere 3PT PTO...
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
Hr:8,875 vin:316000649 (A55787)
Hr:8,875...
