JD 675B skid steer hyd. charge issue
   / JD 675B skid steer hyd. charge issue #1
jchilcot
Morrisdale PA
1994 John Deere 675B
Hi new member here. I have a skid steer that I recently purchased for some landscaping/brush removal from my property. When I run it the Hyd. charge light comes on. I cleaned the suction screen. It was pretty dirty. I thought for sure that would fix the problem but it hasnt. I have noticed that it will work fine until I lift the boom a couple times. Then it comes on and stays on. Everything seems to still work ok but the engine loses power if I start to work it hard. I have read a trouble shooting guide for the machine and what I got from that is it could be the pressure relief valve. Any thoughts on that? The hydraulic resovoir is full. I dont think its the sender due to the way it is running.
Its a JD 675B by the way.
   / JD 675B skid steer hyd. charge issue #2
Did you also change both hyd filters when you cleaned sump screen?
MG9800098 FILTER ADD 16.29 USD
PMHF28810 HYD. FILTER ADD 20.81 USD
I bought some new filters today. Ill put them on tomorrow.
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
2003 John Deere 310SG (A47477)
2003 John Deere...
black Max power washer (A55787)
black Max power...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
