Tiller JD 670 Tiller Clutch Question- Now with Photos
   / JD 670 Tiller Clutch Question- Now with Photos #1
FarmerJeff
Thanks for your patience guys as I get the hang of this site. In my first posting (that was deleted due to a bad link to a JD site), I described a problem with a used JD 670 tiller that I just bought. When buying, I was told that it needed a new slip clutch. I like to fix things myself so I figured, no problem. I have been all through this forum though, and have not seen a lot of info regarding the four-bolt Belleville spring plate style clutch that I have.
I am going to post a series of pictures with questions. Any help would be much appreciated.
The first image here is a generic sketch of a clutch very similar to mine except that mine has four bolts instead of six and is enclosed in its own housing.
Alright- I screwed it up again. /forums/images/graemlins/blush.gif I guess you can't put up photos directly here. I have added the photos at the following link:
Clutch photos
Here is what is going on-
Photo 1: Exploded clutch to show basic parts.
Photos 2-4: Show housing around clutch plates and friction plates. Housing is bent inward at 4 places and slightly overlaps belleville spring thus holding it wedged in place. I cannot tell if this is the intended design, or if this is damage or something done by a previous owner. How can I get the plates out? Do I need to beat the steel housing back into shape? Anyhelp is much appreciated. Thank you.
-Jeff
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
John Deere HPX Gator (RUNS) (A50774)
John Deere HPX...
Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
Lull Highlander...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2012 Ram 3500 Crew Cab Mason Dump Truck (A50323)
2012 Ram 3500 Crew...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI GY-PG72C...
