JD 660 Tiller
/ JD 660 Tiller #1
jhortonvt
Northwestern VT, On Lake Champlain
John Deere 4310
I saw a JD 660 tiller in the paper for $1300. Now, I haven't seen it or even talked to the guy yet, but I've got some ?'s ...
Here's what I've found out so far:
-60" tilling width
-18" cutting circle
-6 blade rotor
-36 blades total
-8" depth
-adjustable slip clutch
-skid shoe depth control
-633 lbs
Does anyone know the years they manufactured this model?
How do they compare to the highly respected brands like Kuhn and Howard (I read in an old post that they were made by Howard-true?)
What do you think bout the price-not knowing condition, etc.
-I saw 3 on machinefinder.com for $1650, $2650, $1595
I'd love some input, I think it would look nice behind my 4310.
/ JD 660 Tiller #2
New CCM MR160 Gear Drive tillers are $1350.
6 tines per flange
60 HP gearbox
Adjustable Skid Shoes
Powder Paint
/ JD 660 Tiller #3
I used to rent that same tiller and it worked great behind my 4300. Went to deal on it this winter, but learned someone beat me to it. It was worn (teeth needed replacing) but it still brought $1000, I was told. I would have tried to deal on it 'with' new teeth, but didn't get the chance.
If the teeth are in good to fairly good condition, I would pay the $1300 for it in a heartbeat.
/ JD 660 Tiller #4
That tiller looks good and even appears it will fit the iMatch or SpeeCo quick tach.
Any outlet in WI or know the shipping cost to here?
PS I thought we 'didn't do' inline photos here. /forums/images/graemlins/confused.gif
Only attachments. /forums/images/graemlins/blush.gif
/ JD 660 Tiller #5
I have the John Deere 660 tiller....it is a well made tiller they are made by Howard.If the tiller is in good shape that is a good price because John Deere charges a lot more than that for them new.
/ JD 660 Tiller #6
Sounds like a good price if the tines are not bent and everything else looks good. I just paid $1400 for a nice used 550, and worth every penny...MM
/ JD 660 Tiller #7
The JD550 & 660 tiller (Howard) models have been discontinued. The primary supplier now is Sicma for John Deere and Maschio for the Frontier tillers.
/ JD 660 Tiller #8
</font><font color="blue" class="small">( <font color="blue"> The JD550 & 660 tiller (Howard) models have been discontinued. </font> )</font>
They are still a good tiller and parts are available for them...the JD 4000 series are discontinued as well.If the tiller is in good shape it would not keep me from buying it discontinued or not...as long as I could get parts.
/ JD 660 Tiller #9
I've had one for several years. The only problem I've ever had was the side cover gasket started leaking. Got the gaskets in 1-2 days and no problems since. Deere specs a two gaskets for the side cover now as the chain can rub on the side cover leading to leaks. Mine hadn't broken through yet so I dodged a bullet. Gaskets were around $20 each.
/ JD 660 Tiller #10
How do the Frontier Tillers stack up against the John Deere series tillers? I was looking at a Frontier Tiller model RT1360 (Heavy Duty rated gear drive, 30-60 HP & 65" cutting width) when I was at the Deere dealer the other day and was told that it listed for about $3500.00 but there was room to haggle. I'm not sure, but as I recall the salesman said that this model was alot more expensive than the previous John Deere brand tillers. He said this was a much heavier built unit than the previous ones in this size range.
I'm going back in a day or so to pick up some hydraulic fluid so I going to check the price again to make sure I heard it right. Anyone heard a price on this tiller (NEW)?
/ JD 660 Tiller #11
The Maschio-Frontier tillers are of the same quality as the JD/Howard tillers. The gear drive Frontier is a good tiller. All of the tiller technology comes from Europe. This is not something new, for 50+ years tillers have not changed much. Many of the tillers sold in the USA are dumbed down versions of the tillers sold in Europe. The average compact tractor owner in the USA uses a tiller less than 4 hours a year. You can purchase the same Maschio tiller for 50-60% of the price that Frontier wants for their tiller at the Deere dealership. If the rebranded tiller was 10-20% more then I could see the value in that you might want a green tiller. The price difference is too much. There are just too many places that would sell you a quality tiller for a better price than $3,500 for a Frontier RT1370.
Take for instance our CCM MR175 Gear Drive 66" tiller is $1450 and has a 70 HP transmission, 6 tines per flange and weighs 75 LBS more than the Maschio/Frontier RT1370. We even offer $0 down financing.
/ JD 660 Tiller #12
CCI,
I gotta hand it to you....you know your tillers... /forums/images/graemlins/wink.gif
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
7 Barrel Masport Vac Pump (A62679)
7 Barrel Masport...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
