jd 650 tractor
   / jd 650 tractor #1
waterguy
Maine
Mahindra 2615hst
does anyone know how many gpm at what pressure the pump puts out . my brother wants to mount a 60" agro trend blower on front with a hydro pump will it work?
   / jd 650 tractor #2
This link helps a bit:
TractorData.com John Deere 650 tractor information
The output pressure is 2030 psi, but it doesn't list gpm. That's a good question for a dealer since they should have the service manuals and specs. If the blower runs off a pump, I think the PTO HP might be a more important spec.
   / jd 650 tractor #3
From the tech manual, the 650 has a 7cc pump that is rated at 4.4 gpm at 2400rpm. If it has the optional power steering, a flow regulator limits that system to 1.1 gpm of the gross output of the hydraulic pump.
   / jd 650 tractor
thank you , i will tell him and see if that will run lt.
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
1268 (A50490)
1268 (A50490)
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2018 Ford Explorer AWD SUV (A48082)
2018 Ford Explorer...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2022 Club Car...
