JD 6220 Left Hand Reverser Issue
   / JD 6220 Left Hand Reverser Issue #1
BBOB57
Chandler, Oklahoma
JD 6220
Greetings,
I have a low hour 6220 with a left had reverser. The last time I used it, it would jump to neutral on the reverser and the tach would quit. Also, I got three flashing warning light on the dash. This happened after about 1 hour of use. I can shut the tractor off for 5 -15 min. and it will work for a while. I looked at the solenoids on the transmission, and the one on the opposite side from the FNR solenoids (#27 on the diagrams I have seen on this forum) appears to have hydraulic fluid in the connector. Can anyone tell me what this solenoid does and can it cause this problem?
Thanks,
   / JD 6220 Left Hand Reverser Issue #2
I cannot, but would suggest getting the service tech manual as it should be a big help with your diagnosing the problem.
Plus likely good help coming from TBN family. I see you have the same thread started elsewhere on TBN.
:welcome: to TBN
   / JD 6220 Left Hand Reverser Issue #3
Has it set any codes? That is where I would start, have the codes read. Engine speed sensor may have failed. Causing computer to think engine is not running. Can you post drawing with solenoid #27?
   / JD 6220 Left Hand Reverser Issue #4
Operator's manual will show you how to read codes.
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
JOHN DEERE 4 BOTTOM PLOW (A52708)
JOHN DEERE 4...
NEW Fork Extensions (A59000)
NEW Fork...
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
2012 Chevrolet Silverado 3500 Ambulance Body VIN # 1GB3K0CL2CF118201 (A57453)
2012 Chevrolet...
LIMA MAC 30KW GENERATOR (A58216)
LIMA MAC 30KW...
