JD 6220 Left Hand Reverser Issue
   / JD 6220 Left Hand Reverser Issue #1
BBOB57
Chandler, Oklahoma
JD 6220
Greetings,
I have a low hour 6220 with a left had reverser. The last time I used it, it would jump to neutral on the reverser and the tach would quit. Also, I got three flashing warning light on the dash. This happened after about 1 hour of use. I can shut the tractor off for 5 -15 min. and it will work for a while. I looked at the solenoids on the transmission, and the one on the opposite side from the FNR solenoids (#27 on the diagrams I have seen on this forum) appears to have hydraulic fluid in the connector. Can anyone tell me what this solenoid does and can it cause this problem?
Thanks,
   / JD 6220 Left Hand Reverser Issue #2
I cannot, but would suggest getting the service tech manual as it should be a big help with your diagnosing the problem.
Plus likely good help coming from TBN family. I see you have the same thread started elsewhere on TBN.
:welcome: to TBN
   / JD 6220 Left Hand Reverser Issue #3
Has it set any codes? That is where I would start, have the codes read. Engine speed sensor may have failed. Causing computer to think engine is not running. Can you post drawing with solenoid #27?
   / JD 6220 Left Hand Reverser Issue #4
Operator's manual will show you how to read codes.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
UNUSED Galvanized Steel Diamond Plate Sheet Metal (A53117)
UNUSED Galvanized...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2007 Allmand Night-Lite Pro Towable Light Tower (A51691)
2007 Allmand...
