jd 620
   / jd 620 #1
alrc
Demotte In
jd 620 & ac wd
I have a john deere 620 that I have replaced the crankshaft seal and it still leaks oil into the transmission. any suggestions?
   / jd 620 #2
Fix the 620 because it's the best model A that Deere ever built.
Be aware of the seal location and the drain hole location. Wouldn't be the first time somebody blocked the drain with the seal and made a leak.
1-800-522-7448 for the service manual and the JD web site for the parts manual. Cheaper than tearing the tractor apart again when it still leaks.
If worse comes to worse. Nothing wrong with draining the stinky old GL-1 from the transmission. And filling it with Shell Rotella T1 straight 50 weight. The viscosity numbers are different with gear vs. engine oil. 50 motor=100 gear oil.
   / jd 620
drain hole is open. do you have any other sugestions?
Genie GTH-5519 (A50123)
Genie GTH-5519...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
WINDLASS 5 HEAD (A53843)
WINDLASS 5 HEAD...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Epic Electric Golf Cart (A51694)
Epic Electric Golf...
2024 Rhino 4155 Batwing Mower (A53473)
2024 Rhino 4155...
