jd 620
   / jd 620 #1
alrc
Demotte In
jd 620 & ac wd
I have a john deere 620 that I have replaced the crankshaft seal and it still leaks oil into the transmission. any suggestions?
   / jd 620 #2
Fix the 620 because it's the best model A that Deere ever built.
Be aware of the seal location and the drain hole location. Wouldn't be the first time somebody blocked the drain with the seal and made a leak.
1-800-522-7448 for the service manual and the JD web site for the parts manual. Cheaper than tearing the tractor apart again when it still leaks.
If worse comes to worse. Nothing wrong with draining the stinky old GL-1 from the transmission. And filling it with Shell Rotella T1 straight 50 weight. The viscosity numbers are different with gear vs. engine oil. 50 motor=100 gear oil.
   / jd 620
drain hole is open. do you have any other sugestions?
2005 Sterling Acterra Tender Truck (A53473)
2005 Sterling...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
