jd 620
   / jd 620 #1
alrc
Demotte In
jd 620 & ac wd
I have a john deere 620 that I have replaced the crankshaft seal and it still leaks oil into the transmission. any suggestions?
   / jd 620 #2
Fix the 620 because it's the best model A that Deere ever built.
Be aware of the seal location and the drain hole location. Wouldn't be the first time somebody blocked the drain with the seal and made a leak.
1-800-522-7448 for the service manual and the JD web site for the parts manual. Cheaper than tearing the tractor apart again when it still leaks.
If worse comes to worse. Nothing wrong with draining the stinky old GL-1 from the transmission. And filling it with Shell Rotella T1 straight 50 weight. The viscosity numbers are different with gear vs. engine oil. 50 motor=100 gear oil.
   / jd 620
drain hole is open. do you have any other sugestions?
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
2015 John Deere 8295R (A50123)
2015 John Deere...
ITEM LOCATION (A53084)
2012 FORD F450 SERVICE TRUCK (A53426)
2012 FORD F450...
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
