Buying Advice JD 5525
/ JD 5525 #1
torn53
I am looking to buy a JD 5525. It is a 2006 model with 400 hrs. It comes with front end loader, 8ft shredder, and hay spear. 45 k seems to be a good price the tractor is in excellent condition. Any comments, suggestions on price and model of tractor?
/ JD 5525
Even with the extras? The tractor is for sure 4x4. Haven't went and looked at it for other details.
/ JD 5525 #4
Some of the options available were pretty costly when new, so there could be quite a price differential between, say a 2wd 5525 with 9x3 trans, no cab, no extra remotes or mid scvs compared to a fully optioned one. Heck of a nice tractor though. Good luck with your tractor hunting!
/ JD 5525 #5
You should be able to get the VIN for the tractor and contact a local JD dealer and have them run the number to generate a build code sheet. Would give you a good idea of what you are going to look at.
/ JD 5525 #6
With new Tier 4 emmision standards coming, this will pull up prices of low hour used
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
1058 (A63291)
1058 (A63291)
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
8' DISC HARROW (A60430)
8' DISC HARROW...
Location Tampa, FL (A61567)
Location Tampa, FL...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
