JD 5400
/ JD 5400 #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
what is a 5400? theres one going to be sold at an auction next saturday. anyone know the hp, maybe the years it was made?? according to the paper, this one has @890 hours on it.
heehaw
/ JD 5400 #2
The 5400 was the first of the 5000 series. ie 5400, 5410, 5420. One difference on the 5400 is that it is a 3cyl turbo instead of the 4cyl non turbo on the 5410 and 5420. I think the 5400 came out around 88-90 and ran till maybe 95 or 96 when the 5410 came out. Give or take a a couple years.
Gary
/ JD 5400 #4
JOHN DEERE
Model = 5400 MFWD
SPECIFICATIONS
Years Mfg: 1992-1997
Fuel: D
Engine Make: JD 3-CYL TURBO
CID: 179
Engine HP: 60 PTO
Cab: OPT
No.Speeds: 9/3
Weight(Pounds): 5,000
List Price: $29,040
PRICING
Year Ad Price Est.Loan Value
1992 $18,005 $11,883
1993 $18,586 $12,267
1994 $19,166 $12,650
1995 $20,909 $13,800
1996 $21,490 $14,183
1997 $21,780 $14,375
Auction Results
MAKE YEAR&MODEL COMMENTS/CONDITION STATE PRICE
JOHN DEERE 1992 5400 D 1200HRS/G MN $18,000.
JOHN DEERE 1998 5400 D 1300HRS/E SD $25,000.
JOHN DEERE 1997 5400 D 437HRS/E ND $20,000.
JOHN DEERE 5400 D 321HRS/E MN $16,200.
JOHN DEERE 5400 D LDR/G MN $11,200.
JOHN DEERE 1996 5400 D 186HRS/E OH $13,500.
JOHN DEERE 5400 D LDR/G OK $15,250.
JOHN DEERE 5400 D LDR/G MO $16,000.
JOHN DEERE 5400 D 1149HRS/E MO $13,500.
JOHN DEERE 5400 D 1145HRS/E MO $12,250.
JOHN DEERE 1994 5400 D 1100HRS/E WI $21,100.
JOHN DEERE 5400 D 1100HRS/E MO $16,500.
JOHN DEERE 1997 5400 D 602HRS/G IA $22,000.
JOHN DEERE 5400 D LDR/E OK $15,300.
JOHN DEERE 5400 D 1400HRS/E MN $17,000.
JOHN DEERE 1995 5400 D 3500HRS/G OK $15,000.
...Excellent Unit! 60 PTO hp for a Turbo 3-cyl...very good hydraulics...
/ JD 5400
thanks all, we will see what happens at the auction. I have decided i just cannot justify or afford a new tractor, so i am looking for something like this with low hours.
heehaw
/ JD 5400
i looked over this information last night, sure seems to be a big price spread at those auctions. i guess it all depends on the crowd. the serial number of the one at this saturdays auction is LVSG057001720, that doesn't tell me if its 4wd or what year, but it has a 520 fel. and a cab, so it will probably go pretty high.
heehaw
/ JD 5400 #7
<font color=blue>...fel. and a cab, so it will probably go pretty high…</font color=blue>
SERIAL NUMBERS
Beginning No. Year
130001 1992
240000 1993
NA 1994
440274 1995
540001 1996
640000 1997
With cab and loader… I don’t think it will be given away…/w3tcompact/icons/wink.gif
Call up your local JD dealer and give them that serial number, to be input in the computer and get a service history printout and particulars…
Good luck… /w3tcompact/icons/smile.gif
/ JD 5400 #8
John,
Is there anyplace to look up specs on balers? I was looking at the last model that deere put out but cna't find the specs on them. I really wanted to know what the 546 and 535 specs were.
Thanks
/ JD 5400 #9
HAY BALERS from JOHN DEERE
Model = 535
SPECIFICATIONS
Years Mfg: 1989- 1996
PTO/Motor: 540 PTO
Type Engine: DNA
Type Bale: 61.6X72
Size Bale: ROUND
Type Tie: DOUBLE
TWINE
Height/Width: 110X112
Weight (Pounds): 4,730
List Price (M.L.S.R.P.): $21,060
PRICING
Year Retail Value
1989 $7,582
1990 $8,003
1991 $8,424
1992 $9,056
1993 $9,477
1994 $9,898
1995 $10,319
1996 $10,951
Avg. Auction Price
LOW HIGH AVG
$4,000 $16,800 $8,667
Auction Results on the 535:
MAKE MODEL YEAR COMMENTS CONDITION STATE PRICE
JOHN DEERE 535 2000 E ND $11,500.
JOHN DEERE 535 MONT G SD $8,000.
JOHN DEERE 535 1995 E SD $10,400.
JOHN DEERE 535 NET WRAP G KS $7,400.
JOHN DEERE 535 G MN $11,000.
JOHN DEERE 535 ROUND G TX $4,600.
JOHN DEERE 535 ROUND G TX $4,250.
JOHN DEERE 535 BIG ROUND E IA $7,000.
JOHN DEERE 535 MONT G OK $8,300.
JOHN DEERE 535 ROUND G KS $5,900.
JOHN DEERE 535 G WI $5,700.
JOHN DEERE 535 E MN $8,600.
JOHN DEERE 535 G KS $6,800.
JOHN DEERE 535 G MN $9,000.
JOHN DEERE 535 G MN $8,800.
JOHN DEERE 535 E IL $9,100.
JOHN DEERE 535 E IL $3,250.
JOHN DEERE 535 G MN $5,500.
JOHN DEERE 535 G MN $6,800.
JOHN DEERE 535 ROUND F IA $7,950.
JOHN DEERE 535 ROUND F IA $6,300.
JOHN DEERE 535 1998 E IA $12,300.
JOHN DEERE 535 G MN $6,500.
JOHN DEERE 535 G MN $7,000.
JOHN DEERE 535 G MO $4,000.
JOHN DEERE 535 G MO $7,000.
JOHN DEERE 535 G TX $6,100.
JOHN DEERE 535 MONITOR F TX $10,500.
Model = 546
SPECIFICATIONS
Years Mfg: 1997- 2000
PTO/Motor: 540 PTO
Type Engine: DNA
Type Bale: 61.6X51
Size Bale: ROUND
Type Tie: TWINE
Height/Width: 92X105"
Weight (Pounds): 3,925
List Price (M.L.S.R.P.): $17,794
PRICING
Year Retail Value
1997 $9,787
1998 $10,321
1999 $11,210
2000 $12,100
Auction Results for 546:No matching records were found.
/ JD 5400 #10
John,
Thanks for the info. Do you know what size bales those make? Also can you get the wrap attachment for that 546? The dealer here has spent two days now and can't give me an answer! Go figure. I've already gotten more info. from you than he has given me.
/ JD 5400
well, i went to the sale, but as i seem to keep running into, some folks "just like new" is different than mine. the brakes didn't work, everytime i pushed on either brake, hydraulic fluid streamed out from underneath the tractor. the top of the cab was broken up pretty bad, and both rear wheel seals were leaking and one still had plastic hay string wrapped around the axle; it went for $19,000. it was a 96 model, the owner had bought it new. from what i was told, and it appeared right from the equipment, he abused his equipment pretty bad, he passed away last year, in his mid 40's.
the NH side rake went for $1400, the vermeer round baler went for $4,000. it needed new chains and sprockets.
heehaw
/ JD 5400 #14
heehaw,
That is sad. I understand what you mean by the like new statement. I've been looking at pickups and have come to realize that mine is "better than new".
Hopefully you will find something soon.
GENERAC MOBILE PRODUCTS  MAGNUM LIGHT/WATER PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
2020 AUTOCAR XSPOTTER TRUCK (A65057)
2020 AUTOCAR...
2013 Mazda 3 Sedan (A66738)
2013 Mazda 3 Sedan...
