JD 535 Baler Problem with belts
/ JD 535 Baler Problem with belts #1
Kebololo2
We have a 1993 John Deere 535 baler and we are unable to keep the belts tight. Anyone have any advise? Thanks!
/ JD 535 Baler Problem with belts #2
Welcome to TBN .
Are you useing OEM belts ? Is the tension is set to mfr's specs ? If you replaceing with automotive type belts they wont last , they stretch too much , way to elastic IMO . You can also use the A n B type machine belts Gates with green strips .
Also check for burrs , misalignment ,improper tension, pulley wobble , proper belt.
How is the condition of your pump ?
/ JD 535 Baler Problem with belts #3
:welcome: to TBN
Maybe describe what seems to be happening.. belts stretching? adjustments slipping?
/ JD 535 Baler Problem with belts #4
Are the belts hydraulic tension? If so you may have a cylinder bypassing.
/ JD 535 Baler Problem with belts #5
Welcome to TBN
Since belts are tightened by hyd tension I'll guess either the tension valve or tension cylinders are leaking internally. Tension cylinders can be checked by individually removing tension cylinder bottom hose then apply pressure similar to closing rear gate. Not many drops of oil should exit open cylinder fitting.
/ JD 535 Baler Problem with belts #6
Did you find out what the problem was?
/ JD 535 Baler Problem with belts #7
i know i'm late but the springs are broke on top of the baler.
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2013 Volvo BL70B 4x4 Extendahoe Loader Backhoe (A64553)
2013 Volvo BL70B...
Landhonor Mini Excavator Ripper Tooth (A66285)
Landhonor Mini...
213078 (A64276)
213078 (A64276)
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
(1) Small Livestock Feeder Gate (A66408)
(1) Small...
