JD 5310
/ JD 5310 #1
Gizmo36
Platinum Member
East of Duewest S.C.
any know were the fuel bleed screws are on a JD 5310 . the fuel pump don't look like any I have seen
/ JD 5310 #2
The only bleed screw is the one on the fuel filter housing. Bleed it at the filter, then loosen the line at the injection pump that comes from the filter. If you get all the air out of that, it should start.
/ JD 5310 #3
That's the way it is on my 5520.
/ JD 5310
I got all the air out at the filter and to the top of the pump. then my battery was dead I will have to go back today and see if it will start.
2012 GORILLA BUILT MANIFOLD TRAILER (A67714)
2012 GORILLA BUILT...
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
2025 Rake Mini Excavator Attachment (A66734)
2025 Rake Mini...
More info coming soon. (A64557)
More info coming...
2014 Ford E-350 Enclosed Service Van (A66736)
2014 Ford E-350...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
