JD 5300 Rear Remote...No Float Position
   / JD 5300 Rear Remote...No Float Position #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I have both a JD 5300 and 5210 both with a single rear remote. The 5210 has float but the 5300 does not. Does the 5300 valve only need the longer cap to allow spool movement for float or will a longer spool be needed also?
   / JD 5300 Rear Remote...No Float Position #2
It requires a whole different valve. You can't just swap some parts.
   / JD 5300 Rear Remote...No Float Position #3
Yes this requires a longer spool for the 4th position and detent assembly.
No clue if parts for 5210 would work on 5300. Whole valve might mount in same place.
2021 FREIGHTLINER CASCADIA DAY CAB (A50046)
2021 FREIGHTLINER...
1983 KENWORTH W900B TANDEM AXLE DAY CAB (A45679)
1983 KENWORTH...
2019 CHEVROLET SILVERADO 1500 TRUCK (A50459)
2019 CHEVROLET...
KSI Conveyor (A50397)
Grove 4x4 Rough Terrain Hydraulic Crane (A49346)
Grove 4x4 Rough...
John Deere TX 4x2 Gator (A47307)
John Deere TX 4x2...
