rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 8,330
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Well, it finally happened. The old JD 530 needs a repair. Runs just fine, but leaving a trail of gassy oil behind so I checked it and found that the crankcase was overflowing with gas in the oil!
I swapped out the needle and float, changed the oil and filter, replaced the aftermarket manual gas shut off valve I had added to the fuel line to the carb 20 years ago, - all to the tune of about $125 - and then drove it around to see what happened. Everything worked like it has for the past 30 years, so I shut it down, closed the aux. gas tap and left it. A few days later I for no good reason went over and to check the oil and it was gassy and the crankcase full to nearly overflowing again!
Wonder what's going on here? I think I know, but thought I'd ask first.
rScotty
rScotty
