Jd 525 stalling
/ Jd 525 stalling #1
lloydn
Just replaced an exciter in a JD 525. Starts fine but dies when I release the brake. Before I start to take things apart, what other than a bad brake switch could cause this? I wonder what I could have done to it while I worked on it. I replaced an exciter that was only 4-5 hours old. Could there be a relationship between the two problems? Would appreciate any suggestions. Thanks, Lloyd
/ Jd 525 stalling #2
Welcome to the forum.
Is the mower switch in the 'on' position, or is a wire off that the safety system thinks the PTO is engaged?
/ Jd 525 stalling #4
I think you are right Dutch. /forums/images/graemlins/wink.gif
/ Jd 525 stalling
I checked the pto and that wasn't on-I'm not sure about loose wires. I'll check that and the seat wires in the morning. Thanks for your help. Lloyd
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
Unverferth Perfecta 12 (A64126)
Unverferth...
2009 IC Corporation School Bus, VIN # 4DRBUAAN39B694287 (A65563)
2009 IC...
2001 Mack Grapple Truck (A64127)
2001 Mack Grapple...
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
1999 Dorsey 42' Aluminum Citrus Trailer (A64127)
1999 Dorsey 42'...
