jd 522 boom cylinder mounts
   / jd 522 boom cylinder mounts #1
jd5205
jd 5205 w/522 fel mfwd
I own a jd 5205 with a 522 fel. The boom cylinder has multiple mounting positions, for various models of older tractors. What I would like to know, is would one benefit from moving the cylinders. If so what do you gain. Lift height, digging depth??? My cylinders are not in the proper mounts according to the labels on the cylinder. What is gained or lost moving them to the alternate mounts?
   / jd 522 boom cylinder mounts #2
You need to determine the mechanical advantage as to where the cyl ends should be.
Can you show pictures?
Possibly give me a few minutes
Here are my photos
   / jd 522 boom cylinder mounts #5
If you move to where they should be, it well give less height more digging. Just make sure they are the right cyls for that loader. I would be asking the dealer why they put them there and not read the sticker. There could be a good reason why they did.
Thanks. I will contact my jd dealer tomorrow and post the results.
2013 MACK GU (GRANITE) (A53843)
2013 MACK GU...
DUMP HOPPER (A53843)
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
