JD 5200
/ JD 5200 #1
LynchWood
Found a 5200 with 520 front end loader 4000hrs,turf tires for 6500 and I was wondering what you all thought about it,tractor is in good shape,and regular oil changes were done every150 hrs.
/ JD 5200 #2
Welcome to TBN - LynchWood (er.. 1 post in goin' on 2 years).
Have a chance to give it a test run? Steering good? Tie rod slop?
The 9x3 tranny is a good one. Very reliable. The 3cyl. 179 C.I. engine is also a bullet-proof engine.
Collar shift or synchro? See how she shifts (no gear complaints if it's a synchro) and if it jumps outta gear, etc.
Loader straight? Pins loose or still pretty tight?
PTO work OK? 3pt work?
4,000 hours can be about right for a clutch replacement - check to see how much adjustment is left - or if it's already been replaced.
Not a bad price.. was it a golf course tractor? With those tires it probably wasn't used in a feedlot!! :D
Best of luck with your decision.
AKfish
/ JD 5200
This tractor has been on a turf farm and is'nt big enough anymore, and that is why they are trading it in for a bigger tractor
/ JD 5200 #4
2wd or 4wd?
/ JD 5200
2wd,we have sold our farm and are now hobby farmers,so I'm satisfied with twd.
/ JD 5200
I'm now an owner of the 5200 and not sure I want to keep the turf tires,does anyone know of any after market upgrades?
/ JD 5200 #8
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2014 FREIGHTLINER CORONADO 122 SD DAY CAB (A63569)
2014 FREIGHTLINER...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
2019 ISUZU NQR S/A 4X2 24FT BOX TRUCK (A59910)
2019 ISUZU NQR S/A...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
RIG MATS (A63569)
RIG MATS (A63569)
