JD 5200
   / JD 5200 #1
LynchWood
Found a 5200 with 520 front end loader 4000hrs,turf tires for 6500 and I was wondering what you all thought about it,tractor is in good shape,and regular oil changes were done every150 hrs.
   / JD 5200 #2
Welcome to TBN - LynchWood (er.. 1 post in goin' on 2 years).
Have a chance to give it a test run? Steering good? Tie rod slop?
The 9x3 tranny is a good one. Very reliable. The 3cyl. 179 C.I. engine is also a bullet-proof engine.
Collar shift or synchro? See how she shifts (no gear complaints if it's a synchro) and if it jumps outta gear, etc.
Loader straight? Pins loose or still pretty tight?
PTO work OK? 3pt work?
4,000 hours can be about right for a clutch replacement - check to see how much adjustment is left - or if it's already been replaced.
Not a bad price.. was it a golf course tractor? With those tires it probably wasn't used in a feedlot!! :D
Best of luck with your decision.
AKfish
   / JD 5200
This tractor has been on a turf farm and is'nt big enough anymore, and that is why they are trading it in for a bigger tractor
   / JD 5200 #4
2wd or 4wd?
   / JD 5200
2wd,we have sold our farm and are now hobby farmers,so I'm satisfied with twd.
   / JD 5200
I'm now an owner of the 5200 and not sure I want to keep the turf tires,does anyone know of any after market upgrades?
   / JD 5200 #8
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
