JD 5115M PTO RPM Gauge Works Intermittently
   / JD 5115M PTO RPM Gauge Works Intermittently #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
JD 5115M PTO RPM Gauge Works Intermittently.
Is this the black sensor on the right side of PTO output shaft ?
Will I loose HyGard Fluid by removing this sensor ?
   / JD 5115M PTO RPM Gauge Works Intermittently #2
Hi Browndog, looks like the the sensor you need is code 58222. Found quite a few with Google search using that code/part number, you can see what it looks like anyway
   / JD 5115M PTO RPM Gauge Works Intermittently #3
Must be something about that sensor. I washed my tractor after sinking it in mud twice in one day and mine was doing the same. Har the tech look at it when he was at the farm and by that time of course it was working again. BD, I'm on the road working so I can't look in the tech manual to answer your question. I would think if it does leak you could get the old one out and the new one in without losing much oil.
I wonder if the sensor has to have a certain gap / clearance to work properly ?
im assuming it’s threaded in.
   / JD 5115M PTO RPM Gauge Works Intermittently #5
It definatally threads in , have you unplugged the wire at the sensor and sprayed with wd40? Might just be bad connection . I don't think there's any adjustment to it
   / JD 5115M PTO RPM Gauge Works Intermittently #6
I am not sure on your tractor, but on my JD 6415, the PTO sensor and ground speed sensor are the same P/N. When I had issues, I swapped them to confirm the sensor was bad.
   / JD 5115M PTO RPM Gauge Works Intermittently #7
Looking at mine I’d say the sensor is just above the oil level in axle
JD didn’t have the $32 sensor in stock today.
I’m going to order one.
the Elc plug is tight, clean & not damaged.
Electrical connector was clean & tight.
I ordered a new RE537634 sensor
   / JD 5115M PTO RPM Gauge Works Intermittently #10
So did the new sensor fix the pto speed readout?
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
19101 (A51694)
19101 (A51694)
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
