JD 5115M PTO RPM Gauge Works Intermittently
   / JD 5115M PTO RPM Gauge Works Intermittently #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
JD 5115M PTO RPM Gauge Works Intermittently.
Is this the black sensor on the right side of PTO output shaft ?
Will I loose HyGard Fluid by removing this sensor ?
   / JD 5115M PTO RPM Gauge Works Intermittently #2
Hi Browndog, looks like the the sensor you need is code 58222. Found quite a few with Google search using that code/part number, you can see what it looks like anyway
   / JD 5115M PTO RPM Gauge Works Intermittently #3
Must be something about that sensor. I washed my tractor after sinking it in mud twice in one day and mine was doing the same. Har the tech look at it when he was at the farm and by that time of course it was working again. BD, I'm on the road working so I can't look in the tech manual to answer your question. I would think if it does leak you could get the old one out and the new one in without losing much oil.
I wonder if the sensor has to have a certain gap / clearance to work properly ?
im assuming it’s threaded in.
   / JD 5115M PTO RPM Gauge Works Intermittently #5
It definatally threads in , have you unplugged the wire at the sensor and sprayed with wd40? Might just be bad connection . I don't think there's any adjustment to it
   / JD 5115M PTO RPM Gauge Works Intermittently #6
I am not sure on your tractor, but on my JD 6415, the PTO sensor and ground speed sensor are the same P/N. When I had issues, I swapped them to confirm the sensor was bad.
   / JD 5115M PTO RPM Gauge Works Intermittently #7
Looking at mine I’d say the sensor is just above the oil level in axle
JD didn’t have the $32 sensor in stock today.
I’m going to order one.
the Elc plug is tight, clean & not damaged.
Electrical connector was clean & tight.
I ordered a new RE537634 sensor
   / JD 5115M PTO RPM Gauge Works Intermittently #10
So did the new sensor fix the pto speed readout?
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2018 INTERNATIONAL LT625 SLEEPER TRUCK (INOPERABLE) (A52472)
2018 INTERNATIONAL...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
