JD 5105M PowrReverser Modulator
   / JD 5105M PowrReverser Modulator #1
bigblock
SW Georgia
JD 5105M
I moved this from the Parts/Repairs Forum in the hope that I could find someone who has the experience of installing one of these kits. Thanks for your patience.
It seems like I read somewhere on here that John Deere can provide a kit to retrofit a modulator for the powrreverser on the 5M series tractors. The 4310 that I had before had a two position switch for that but I could never detect much difference between the switch positions. The 4310 seemed to modulate itself better than the 5105M, which just seems a little too abrupt, even if I allow it to return to idle before changing directions.
I would appreciate hearing from someone who has experience installing that kit. Seems like it was said to cost about $100 if I remember correctly.
Thanks.
   / JD 5105M PowrReverser Modulator #2
I installed it on mine.
It goes here:
You just knock out or drill out the hole, attach the label, insert the knob in the hole and tighten, then plug it into the harness already there.
The catch is that the dealer needs to program the engine computer before it will work.
It goes here:
Thanks, you were the guy I was looking for! I appreciate your response, picture and all. Is the programming with a laptop or do I have take the tractor to the dealership?
1999 JEEP WRANGLER (A50459)
1999 JEEP WRANGLER...
377758 (A48836)
377758 (A48836)
2012 INTERNATIONAL TERRASTAR SFA 4X2 SERVICE TRUCK (A50459)
2012 INTERNATIONAL...
2007 Ford F550 Flatbed (A50397)
2007 Ford F550...
2007 Ford Crown Victoria Sedan (A50860)
2007 Ford Crown...
2003 Volvo VNL Sleeper Truck, VIN # 4V4NC9TG33N340135 (A48836)
2003 Volvo VNL...
