JD 5105M PowrReverser Modulator
   / JD 5105M PowrReverser Modulator #1
bigblock
SW Georgia
JD 5105M
I moved this from the Parts/Repairs Forum in the hope that I could find someone who has the experience of installing one of these kits. Thanks for your patience.
It seems like I read somewhere on here that John Deere can provide a kit to retrofit a modulator for the powrreverser on the 5M series tractors. The 4310 that I had before had a two position switch for that but I could never detect much difference between the switch positions. The 4310 seemed to modulate itself better than the 5105M, which just seems a little too abrupt, even if I allow it to return to idle before changing directions.
I would appreciate hearing from someone who has experience installing that kit. Seems like it was said to cost about $100 if I remember correctly.
Thanks.
   / JD 5105M PowrReverser Modulator #2
I installed it on mine.
It goes here:
You just knock out or drill out the hole, attach the label, insert the knob in the hole and tighten, then plug it into the harness already there.
The catch is that the dealer needs to program the engine computer before it will work.
It goes here:
Thanks, you were the guy I was looking for! I appreciate your response, picture and all. Is the programming with a laptop or do I have take the tractor to the dealership?
2007 UD Truck UD2600 Truck, VIN # JNAPA80H87AN61005 (A48836)
2007 UD Truck...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A50458)
2018 CATERPILLAR...
2011 CATERPILLAR 289C SKID STEER (A50458)
2011 CATERPILLAR...
LOWRY 5' DISC HARROW (A50459)
LOWRY 5' DISC...
2012 Ford F-350 Mechanics Service Truck (A48081)
2012 Ford F-350...
2018 Nissan Versa SV Sedan (A48082)
2018 Nissan Versa...
