jd 5103 3 pt lift
   / jd 5103 3 pt lift #1
smithra9
john deere 5103
i have a jd 5103 and i am having trouble with my 3 pt lift. it will no longer raise all the way up with an attachment hooked up. i can raise levers all the way but attacment will only go about half way. i can raise the attachment by hand and it will finishing raising up but will go right back down to about half way.
any suggestions would be appreciated
   / jd 5103 3 pt lift #2
check position of draft control lever.
   / jd 5103 3 pt lift
all of that is working fine it will pick up if i lift on bushhog by hand but will go back down i am being told about a valve that is internal?????
   / jd 5103 3 pt lift #4
What year and how many hours?
   / jd 5103 3 pt lift
2003 345 hours
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Lift Gate (A52377)
Lift Gate (A52377)
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
2019 DODGE RAM 3500 (A52472)
2019 DODGE RAM...
2014 FORD F150 4X4 CREW CAB PICKUP TRUCK (A52576)
2014 FORD F150 4X4...
