jd 5103 3 pt lift
   / jd 5103 3 pt lift #1
smithra9
john deere 5103
i have a jd 5103 and i am having trouble with my 3 pt lift. it will no longer raise all the way up with an attachment hooked up. i can raise levers all the way but attacment will only go about half way. i can raise the attachment by hand and it will finishing raising up but will go right back down to about half way.
any suggestions would be appreciated
   / jd 5103 3 pt lift #2
check position of draft control lever.
   / jd 5103 3 pt lift
all of that is working fine it will pick up if i lift on bushhog by hand but will go back down i am being told about a valve that is internal?????
   / jd 5103 3 pt lift #4
What year and how many hours?
   / jd 5103 3 pt lift
2003 345 hours
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
