JD 5075E Shifter Lever will not go into 3rd or 4th gear
   / JD 5075E Shifter Lever will not go into 3rd or 4th gear #1
MicaiahLindquist
John Deere 5075E
Hey y'all, new here. Was hoping to find some help with my 5075E. Was out running it a couple days ago and it was shifting into all the gears and acting normal and then randomly one time I went to go back into 3rd from second (just going down the road, no implements running) and the shifter lever was extremely stiff. I stopped the tractor, turned it on and off, shifted throughout the range gears, and still nothing. Even when off in neutral with the clutch down it takes a ton of force to push the shifter into 3rd and when you do with the tractor on the neutral light will flash on. No alarms are error lights. Hydraulic fluid is full. The manual suggests the linkage is stuck. Does that sound like it could be the problem? If so, what the best way to fix that. Thanks!
   / JD 5075E Shifter Lever will not go into 3rd or 4th gear #2
Welcome to TBN
A thought is linkage might be a problem, is to oil those linkages to try to rule that out as the problem. Sounds doable as well as a prudent first move. Easier than a more in-depth issue.
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
(2) CASE IRON POT BELLIE STOVES (A58374)
(2) CASE IRON POT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
