JD 5065M newbie with cold weather start problems - advice needed.
   / JD 5065M newbie with cold weather start problems - advice needed.
Update:
Tonight was a bit warmer (+9F) and I was able with repeated tries to start and successfully operate the tractor for an hour or so. The battery was dead and needed a good charge so it will sit on the charger overnight. Obviously, there is no proving or disproving any of our theories at this point. Warmer weather is yet ahead so I will report back on what I have found.
The only therapy waas to add some Power Service additive with Cetane boost to the fuel tank at the appropriate concentration.
   / JD 5065M newbie with cold weather start problems - advice needed. #12
Consider pulling the fuel filter and replacing with a new one.
Consider parking near an electrical outlet. That would give many more options.
Do you have an inlet air heater or glow plugs?:D
Egon,
The tractor is parked 3 feet from an electrical outlet. I have glow plugs, but no inlet air heater.
Tractor ran last night with only a slight difficulty getting it started in 19 degree air. Battery is dying and won't take 24 hours worth of 10 amp 12 volt charge. I find this odd because the tractor is only 18 mos. old. I will try to pull the battery to have it tested this weekend at a battery retailer near me.
tmac
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
3in Poly Pipe (A49461)
Oil Well Pump Jack with Motor (A49461)
Oil Well Pump Jack...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
