JD 5065M newbie with cold weather start problems - advice needed.
   / JD 5065M newbie with cold weather start problems - advice needed.
Update:
Tonight was a bit warmer (+9F) and I was able with repeated tries to start and successfully operate the tractor for an hour or so. The battery was dead and needed a good charge so it will sit on the charger overnight. Obviously, there is no proving or disproving any of our theories at this point. Warmer weather is yet ahead so I will report back on what I have found.
The only therapy waas to add some Power Service additive with Cetane boost to the fuel tank at the appropriate concentration.
   / JD 5065M newbie with cold weather start problems - advice needed. #12
Consider pulling the fuel filter and replacing with a new one.
Consider parking near an electrical outlet. That would give many more options.
Do you have an inlet air heater or glow plugs?:D
Egon,
The tractor is parked 3 feet from an electrical outlet. I have glow plugs, but no inlet air heater.
Tractor ran last night with only a slight difficulty getting it started in 19 degree air. Battery is dying and won't take 24 hours worth of 10 amp 12 volt charge. I find this odd because the tractor is only 18 mos. old. I will try to pull the battery to have it tested this weekend at a battery retailer near me.
tmac
LOT LOCATIONS (A52141)
Avco / New Idea Hayrake (A50515)
Avco / New Idea...
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
12 ft Chisel Plow with Rolling Baskets (A52128)
12 ft Chisel Plow...
