JD 5065E and a 3 Bottom?
/ JD 5065E and a 3 Bottom? #1
ericrm2005
Central Pennsylvania
Considering the 5065E 4x4 and still doing some research. Really strugling with making a decision on this. I was wondering if anyone with this tractor or a smilar tractor and similar soils would know if it could pull a 3 bottom 16" plow. I am going to be doing some field work, however not a lot of field work. A 2 bottom plow would probably be too small for what Ill need. I live in central pa and have fairly rocky soil. The soil is somewhat clay, however not really bad. Anyone with any input would be great. Thanks.
/ JD 5065E and a 3 Bottom? #2
I have heard 20HP per bottom.
That with 4 wheel drive it will act like it has more HP pulling.
No in clay or rocks, my 2030 (60HP) two wheel drive, pulled a 3 bottom without a problem.
I have heard 20 HP per bottom also, but I do guess it varies from place to place. My gut is telling me that it may pull a 3. I would hate to buy it and not be able to pull it though.
/ JD 5065E and a 3 Bottom? #4
A 65 hp(179 cid) 5065 MFWD should be able to handle a 3X16 moldboard. Years ago I pulled a 2X14 plow with a 17.5 hp(149 cid) JD BO. But that was back when horses were Clydesdale's not Shetland ponies.
/ JD 5065E and a 3 Bottom? #5
I would recommend a 5075E, I had a 5510 (89HP) would be better. Just coming from experience. If you have the money you should get bigger power. Since you have clay soil.
2R ROTARY HOE (A63291)
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
NEW HOLLAND LB75 BACKHOE (A63291)
NEW HOLLAND LB75...
Location Tampa, FL (A61567)
Location Tampa, FL...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
