JD 500B Industrial backhoe loader Hydro Pump question.
   / JD 500B Industrial backhoe loader Hydro Pump question. #11
TxJim. JD parts shows a mid mount hydraulic pump that is not the trans pump. I think you two are talking about two different pumps
The gears in Z5's diagram appear to be drive gears not a pump plus photo heading is as follows "mid-mounted hydraulic pump drive". Isn't mid-mount pump the standard 8 piston pump similar to photo below?
   / JD 500B Industrial backhoe loader Hydro Pump question. #12
You are correct. I posted the mount for the mid mount pump. Had I posted the pump, which looks the same as a front pump, I did not think you would see there was an external mid mount pump.
I will post a picture as soon as I get the other hose on and get it out of the mud. I appreciate the help guys
Sorry it took so long, so if you are still following the thread I am attaching a picture of the pump location and the image from the service manual. Granted neither pic is very good....
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
UNUSED INDUSTRIAS AMERICA F12T HYD TILT LAND LEVEL (A51247)
UNUSED INDUSTRIAS...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
